File structure graphics
Here's a small suggestion, for some future release . . .
The show file directory make no graphical difference between a show file and a folder, except for the length of the file name.
I'd love to see a little more differention between the folder names, and the ESF files.  Kind of like the folder graphic and document graphic when looking at a Windows directory.  The Bold not Bold would have worked, but that is already used for a single show file, or file with previous copies (don't consider changing this.  This is good)
OtherShowFiles
     High School Shows
     MusicFest Shows
     EmilyCarr Grad 2010-07-15 13-11-31.esf
     Mariachi Festival 20910-05-07 17-20-50.esf
I like having the ability to clean up the harddrive (delete and re-arrange old show files) from the Utilities shell.  Can it be possible to RENAME folders or files.  Right now it's only create, delete, or move.
Andrew
  • Andrew, yep, we were just talking about that a couple of weeks ago.  Additionally, when working in the browser, if you have a large number of showfiles, you can sort of lose the menu field you are in (open, save as, etc).  So, we will be addressing that as well.
    Agree that renaming folders from the shell is a good idea.  I can't imagine there would be a problem with renaming files, but will check with the developers.   On the list!!
    a
