Hello all,
Any way to make an element (rectangle assigned to cue - active) flash green when the go button is pressed, or have a separate element assigned to the go button that lights up when it's pressed?
TYIA
Hello all,
TYIA
There is no built-in console functionality like this. You could fake it with a dummy channel that runs a one-shot effect in every cue and tie that channel's intensity to the magic sheet object you want to blink.
While this would work it's probably not a very elegant solution.
