Hide cue list number in [About] + [Next] / [Last]
I've recently started using About + Next / Last to see how far a track or trace will go. But with any more than 3 digit cue numbers its hard to see what number its showing me. It'd be nice to have a setting to suppress the list number from this view. Failing that can you remove the spaces so its not 1 / 2451 and it become 1/2451?
  • For this function (to see where things are tracking) I use blind spreadsheet mode. If you haven't tried that, go into blind and then press the format button until the spreadsheet is active. Then type in the chanel number and you will see what is going to happen in one view. you can make it show all data or just the intensities by pressing shift + format. See more here https://www.etcconnect.com/WebDocs/Controls/EosFamilyOnlineHelp/en/Content/04_System_Basics/04_Live_and_Blind_[Tab_1]/Spreadsheet_Blind_Only.htm
    If you already know this feel free to ignore this response.
    Regards
    Geoff
  • Yeah, unfortunately with the..... quality of apex hardware..... it takes a small lifetime to go in and out of blind spreadsheet. Also, in tech who really has time to go into blind when you hit update.
