Fixture library 3.3.0.212
On my first show using our new Stadales, my off-line prep using A3d was not as useful as I expected. The problem is TILT - the units were simply not tilting far enough. The front of house units were not reaching the stage. I have found the cause of this.
The user manual says
"Tilt Degree
With this function, you can select the total Tilt degree range
between 270, 540 or 360SC."
The DEFAULT setup for "Tilt Degree" is 270.
The EOS Profile has the tilt range from -270 to +270 which is 540degrees in total.
