Return at end of label appears to add an extra space (but doesn't)
Eos Ti, but also seen it on other console types, 3.3.5b69
Definitely annoying rather than a serious issue, but:
If you use label, type some text, then press enter, at the moment you press enter the label cursor jumps to the right as if it's added an extra space.
It didn't used to do this. And while it's not actually adding a space, it is disconcerting, especially if you're dinging something like entering a text string for OSC or similar where that extra space would potentially mess things up.
