Hi
how can i export my DMX patch so that i can print it?
i tried some things with the print-option at [displays] but i don't get it onto my USB-stick.
Lukas
Hi
Lukas
Hi Lukas,
You should be able to put the USB stick in and the from the browser select Print -> Print To File and then scroll down until you see the USB drive. Click on this. If the directory was already open, try closing and reopening to refresh the view. If you can see the drive on file saves, then you should be able to see it for printing also.
Once the save window opens, select PATCH and DMX PATCH. In 1.9.5 you will not need to select both to get the DMX Patch, but you will need to write out both in current released code. This should create a .pdf file on the USB drive.
Ann
Is there a way to get it in some form other than a PDF (i.e. csv file so that it could be imported into Excel)?
Hi Jay,
Yes, you can export as a CSV file also.
Ann
ok
first i got a windows error :-D (runtime error)
but now i've got it on my usb-stick, thanks!
