Int-Sub: Intensity snaps to full when GM exempt in patch.
When having a Sub as Int master with 1 Channel @ Full and having this channel  "GM exempt enable" in patch, intensitiy snaps to full as soon as the submaster is >0%.
As soon as the GM exempt is disabled in patch attributes, the intensity fades from 0 to 100 again.
Also as soon as the sub is changed to prop master, everything is fine, even though the GM exempt is still enabled.
Am I missing something? Is the intensity behaving like a NIP as soon as the GM exempt is enabled?
