Hey All,
I have a routine I've used in the past to get cue sheets prepared in Excel imported into Eos. I know this works, but I haven't used it for a while.
In trying today, it doesn't work. The import says 'success!', but no cues appear.
I suspect that's Eos software-version related. If I export a CSV file from the Eos version I'm trying to import in to, I can see some extra fields have appeared compared to last time I did this, eg. TARGET_DCID, ALERT_TIME, WIDTH, HEIGHT.
I've adapted my exporter to export these fields, but with no content. But the cues are still not coming into Eos.
My suspicion is that Eos is now looking for a TARGET_DCID, which I suspect is a cue-number-independent identifier for a cue (a long, multi-digit identifier, looking at my test export file), for each cue. I wonder if because this field is blank in my 'to be imported' file, nothing is being imported?
Or is there some other field that has to have data for a cue to appear? For example, there is no cue timing in my to be imported file?
Any thoughts or suggestions gratefully received, as it'd be great not to have to type all this stuff in again!!
