Previous manual cues remain active (red) after Go – how can I prevent this?
Hi everyone,
I'm having a small issue with my setup. I'm running a Gio @5 as the primary console with an Ion Xe 20 as a client.
When I run cues manually, the previous cues remain active and stay highlighted in red, even though their fade time is 0. As a result, I end up with multiple active cues. To get back to having only the current cue highlighted in yellow, I have to do a Go To Cue.
It doesn't seem to be related to Mark timing.
Has anyone experienced this before or knows what could be causing it?
Thanks a lot for your help!
