Magic Sheet drag selecting inside of shapes
Hi, I am wondering if there is a way to create a selection box starting from inside a shape. For example selecting channels 1 through 5 in the following picture:
I am used to 3.1 where you could simply drag inside of the square shape and it would create a selection box, but as I understand it currently drag clicking will move the shape instead. In comparison in v3.1 you would have had to click the shape on its own, then drag after.
I can start the drag from outside of the box but I am used to creating multiple of these boxes next to each other to section information so a box in the middle would not have this option. I have tried shortcuts (shift ctrl alt clicking etc) but can't find anything.
  • Selecting things is not easy with boxes surrounding them.
    You have tree ways of selecting things:
    1. klick it; using [shift]+Click or [Ctrl]+Click to select more individual. And using [Ctrl]+Click to deselect individuals out of many
    2. Drag from down-right to top-left -> will select everything that touches the selction-Box
    3. drag from top-left to down-right -> will only select everthing that is fully enclosed in the selection-Box
    Helpfull?
  • My problem is that options 2. and 3. do not work when you start dragging from within the object. I was just wondering if there is a way to create a selection box from within an object without dragging the object itself, because it's a feature that's seemingly been removed between 3.1 and 3.3.
