3.3.9, but also 3.3.8. aRFR 4.1.7
aRFR can't control a parameter called "Fan". Using the virtual encoder in aRFR, including the Min/Max buttons, controls Intensity. Tapping the encoder header to write the parameter name to the command line fails with a syntax error.
This is what diagnostic tab shows. The first line is when tapping the parameter name in the aRFR encoder, the second line is when using the console's parameter tile in the CIA to specify the same parameter.
thx, ueli
