Is there a way to quickly patch a series of channels?
I have twenty-two LED fixtures addressed sequentially in a single universe, and they are all the same type of fixture. Is there a way for me to select all the channels I want to use for each fixture, provide the starting address for the first channel, and have the rest auto-address themselves based on the number of channels required by the fixture type?
  • Go to Patch.  Select the Channels you want to use.  (i.e. 601 thru 622 Enter).  With them selected, assign the correct type of fixture using the 'Type' Box to the bottom left of the screen.  Now Select the Channels again (they are probably still selected) and set the first address and the rest will fill in for you in sequence, using the correct number of DMX addresses for each fixture.
