We discovered a small, surprising bug.
We're using a multiconsole system with different users for each device.
Version: 3.3.9
Two operators, both open the patch.
first one types: channel 1001, then he scrolls down with the page down keyuntil the selected channel is no longer visible on the screen
second operator: selects a channel and changes the label, press enter
on the screen of the first, the display jumps back to the selected channel 1001.
remember: different user, different boards
and the second one have to change the label, it's not failing if you only open the label and enter it or open label, delete last letter and type same again. the label has to be different.
the selected channel from operator one must no longer be visible on the screen
We had a good laugh trying to figure out what had just happened
