Hi. We've been using the Group Cue function to make a reference group for refocus in the rep - so Group Cue 0.5 thru [final show cue] which is brilliant. The only problem is it seems to capture channels that never have an intensity value if the have a zero blocked value in a non-block cue. For example if a channel was added then removed in plotting but the EOS has done its auto-block lower-case-b thing. Is there any way around this, or do I just need to tidy up before i do my group at the end of each day?
