Patched and unpatched channels
Hi guys,
Here's my thoughts on the channel screen:  On the 500's, I was very comfortable with two screens making 400 channels.  I really dig the zoom feature on the Eos.  It is so much easier than changing your display resolution to see more/less channels.  I will find a setting on the Eos that will give me something in that 400 channel neighborhood to be my standard Live screen look.  When I program my own shows, I like to start with those 400 channels existing, but indicating an unpatched status.  Then I am able to lay out my patch structure visually, with different systems in different areas of the screens.  That way, until I have channel numbers memorized I only have to remember, say, that the cycs are in the bottom left, the ground row next to that, the fronts on top, washes in the middle, and so on.  When working this way, I avoid deleting channels, as that shifts the grid around, mucking up my visual organization.  Will (does) the flexichannel patched mode show all channels with an indication between patched and un, or is it only the channels that are patched with no fixed layout?
  • Hello!!  Welcome back.  Patched channels (flexi state) shows only those channels that are patched, with no fixed layout.   In 1.3, we are adding the  condition of "deleted channels".  Right now, we don't differentiate between an unpatched channel and a deleted channel.   When we implement deleted channels, the bottom of the "tombstone" of a deleted channel will not be displayed.    So, when that is done, I think your best option - to maintain a fixed format - would be to not use flexichannel, as flexichannel will always be conditional on deleted/patched states (in addition to all of those other states).
    Down the road..... you'll have some different options for screen layouts.
    Does this help?
    a
    [edited by: Anne Valentino at 12:54 PM (GMT -6) on Fri, Aug 31 2007]
