focus Palette - Drifting issue
When updating cues, the focus Palette's re-program there location ( Drifting position)
ie.  chan 21(whitch is a I-que attached to a S4)   live cue:23   chan21 @60 {enter}  {update}
which sometimes.. moves the focus point and updates it at the wrong (X & Y Position)  without the user giving the command to updated the Focus point. only the dimmer %
any ideas? or suggestions
Info On Equipment:
Uvic has the ETC EOS # 3 &4 off the assembly Line of the ETC model.
ETC Eos lighting Board, ETC Dimmers, Source four senior, and Rosco I-Que 16bit, Apollo Power Units,
Route of Information>  ETC Board --(via cat5)-->Dimmers--(viacat5)-->Node(gateway)--(DMX512)--> Powerunit- DMX 4pin->I-que--(4pin-return)-->powerunit.
Thanks In Advance,
[edited by: Kent@Uvic at 9:21 PM (GMT -6) on Sun, Oct 10 2010] More info added.
  • Hi Kent,
    It sounds like you are making some manual changes made to the position of the iCues before you update a cue, thus updating the Focus Palletes.   By default, the console will update all referenced data in a cue, in addition to the cue itself, when you hit update and enter.
    For example -- if you have a moving light that is currently in Focus Palette 2, Color Palette 14, and Beam Palette 4, and you change the intensity, focus, color, or beam, then update the active cue, you will update the cue and any changed palettes. Anything that references FP2, CP14, or BP4 will play back with the new values.
    EDIT: Presets function in much the same way.
    You can change this functionality on a case-by-case basis by pressing Make Absolute (S2, or in the Update window that pops up), or altering the default functionality by going to Setup -> Desk -> Record Defaults.
    Hans
    [edited by: Hans.Hinrichsen at 12:49 PM (GMT -6) on Mon, Oct 11 2010]
  • The syntax you've written above is to update all manual (red) values into the current cue.
    - Hitting Enter completed the intensity command, so the [Update] command doesn't refer to it.
    Basically, unless you specifically tell it otherwise an Update command will update all manual values, and as Hans said, by default this will update the references used in the cue.
    There are also options when Updating to specify how far down the chain of references to update, given in the softkey and CIA areas.
    - For example, one might want to update the source Preset but not the Palettes used in that Preset.
    Finally, thanks for the summary of your lighting system, as that kind of information is indeed very useful when providing assistance. However, you did accidentally miss out the software version of the Eos, which would be very useful if you have further questions.
  • Problem Solved, a ETC Technician was hired to come and fix our Network Switch and Update us to NEt3/sACN
