effectlist and curvelist on display
Is there a possibility to make the lists of curves and effects (and may some other things aswell) visible when I press the buttons for these two?
Example: I need to adjust the curve for a certain dimmer. I select the dimmer and then press curve. If I press curve a small list appears in the screen so that I don't have to know these by head or go all the way into the setup etc., etc.. Now it takes a lot of extra time to change this.
Same with effects (although that's already a little bit easier). If I press effect a small pop up screen appears with the effectlist
Edwin van Steenbergen
