Cue List
Hi
     How do I assign a cue list to the playback master?
Ta
Aidrian
  • Hi Adrian,
    Are you working on Eos or Ion?
    Ion has a button above the main playback labelled load, on Eos there is also a button above the main playback which performs the same function, but doesn't actually have a label. To assign the cuelist you just need to choose the list with the following syntax and hit the load button - [Cue] [x][/][Enter][Load]
    To load to other playbacks on Eos just use the half moon button above the relevant fader. On a fader wing you can push both of the buttons beneath the fader at the same time to achieve 'Load'.
    Hope that helps
    Graham
