Cyc Effects with RGBWA LED battens
Starting a project with 18 RGBWA LED Colorado Batten 72 fixtures - rear lighting cyc from bottom and top in Block-2 mode.
Anyone have any special wisdom learned from how ION effects treats Amber and White parmeters (or just use RGB paramters?) - fixtures are still on order - just trying to plan ahead and get advance guidance.  Plan on putting each segment of batten (3 per) as independent fixture, as with generic RGB fixtures.
  • J2-AV ---- as you are running 1.9.1 (hopefully), you should be fine as long as you are aware that if you set your color values through the gel picker or color picker, the "non-standard" LEDs (that would be the W and A) are not included in the color mix.   So, for now, you are probably going to want to:
    Mix your color in native (RGBWA) space
    Or mix with the HS tools, convert (via color format) to native and add W and A as needed.
    Just so you know, 1.9.5 adds the ability to include W and A parameters when using HS.
    Hope that helps.
    a
