I'm sure many of you have done this countless times, but I'm not having much luck trying to find the best way to do this. I need a quick, simple way to easily update focus palettes repeatedly, like you would do during Mover Focus for a tour. My first instinct was to build a cue list that stepped through each instrument at each focus point that needed to be updated, and while this works fine, it is annoying to have to re-select the next fixture each time I Update. I'm more looking for something similar to Rem Dim or Channel Check that steps through the selected channels and keeps the active one selected, except that both of those commands use the command line, which gets cleared every time I Update.
Hope that makes sense. Thanks in advance!
Michael Roche
