Tabs Ion
Could someone point me toward the correct Ion training video (or doc) that demonstrates the use of the tab feature? Particulary opening direct select buttons in a tab and the removing the tab when programming is done
Steve
    Steve, please see the following (taken from the Eos 1.7 manual). Let me know if you need more info!
    Selecting Displays
    When a display is selected, the screen is highlighted in a gold border and the display name (such
    as "1. Live Channel") will be in gold as well. When a display is not selected, there is no border and
    the tab name is grey.
    If a display is already open, it can be selected in the following ways:
    • Press [Tab] to change focus from the currently selected tab to the tab immediately to the right.
    If no tabs are to the right, the selection moves to the first tab on the left of all available monitors.
    • Press [Tab] & [n], where "n" represents the tab number of the desired tab.
    • Press [Live] or [Blind] to automatically bring live/blind into focus. If there are multiple
    instances of live/blind, pressing [Live] or [Blind] brings the next live/blind tab into focus.
    • Double press a record target button (such as [Preset] or [Submaster]) to either open the
    associated display or select it if it is already open.
    To remove a display from a touchscreen:
    Step 1: Select the display by pressing [Tab] & [display number] together. Display number is
    indicated at the bottom left corner of the display (for example, "1. Live Channel").
    When selected, it is highlighted in gold.
    Step 2: Move the selected display by pressing [Tab] & [Page ] or [Page ] together. The
    display will move to the next available screen. You may have to do this more than
    once to move it entirely off of the touchscreens. You can also close Tabs 3 and higher
    by pressing [Escape].
    For more information on moving displays,
    As for Direct Selects
    [Displays]
    Navigate within the CIA down to {Virtual Controls} then {5x10 Direct Select Module}  and {Open in Tab}
    Hope this help!
  • Steve, you might also see a sticky post at the top of the forums called "help with displays."  There is a PDF posted there that might be of use.
    a
