chanel time in pdf file
how did you make for see the particulary's time in pdf show if you don't use the cue part but just chanel time ?
excuse me for my bad english
  • Hi,
    If I understand your question correctly, you wish to see a discrete channel or parameter time, not just the cue or category time.  This is possible in the pdf file if you turn off the "Summary View" option when you open the print window.  "Summary View" is the default, but pressing this key will turn it off and enable "Full View" which prints more information.  Here is an example which has channel 5 time of 3.3, focus time of 1.5 and scroller time of 4.5.  Note that the times are located under the parameter type.
    Cue 1/1
    Times: Up 5 Down 5 Focus 5 Color 5 Beam 5
    Delays: Up 0 Down 0 Focus 0 Color 0 Beam 0
    Duration: 5
    Channel  1      2     3      4      5     6      7      8     9    10   11
    Intens: 100 100 100 100 100 100 100 100 100 100 100
    Time:                                    3.3
    Pan: - - - - - - - - - - -  44
    Time: 1.5
    Tilt: - - - - - - - - - - - - 44
    Time: 1.5
    Hue: - - - - - - - - - - -  0
    Saturatn: - - - - - - - -  0
    Scroller: - - - - - - - - - 3
    Time: 4.5
    Is this what you were looking for?
    Ann
  • Dear Ann ,
    That's not what I meant.
    I wanted to know if it's possible to see the special time(s)of one or more channels in the pdf printout
    best regards
    Steph
