How to fix a color change?
Have you ever tried to crossfade from amber to blue on a fixture with dichroic flags only to end up going straight through a green that ruins the whole effect?  Is there any way to force the EOS color picker to go the long way around the color wheel or even through the center?  I have been told that I can put more cues in between (i.e. Amber then Pink then White then Pale Blue then Saturate Blue) but I am wondering if there is a more elegant solution.
