Ion ver. 1.9 Patch 1.0 GA Build 30 ~ 1.9.1.9.0.30
Mid-day today, suddenly, I lost proper control of my page up & down buttons. I'm not sure what I keyed to get this situation(was it a combination of keys?, I don't know), but I was using select last, flexi and page up & page down for sure. The Page button now jumps from multi-intensity fixture to the next multi-intensity fixture, skipping the regular dimmer channels. When it jumps to the next multi-intensity fixture channel it places that next channel on the command line. Example: Chan 2101 Intens_
When I Clear the command line it releases the tombstone but, DOESN'T release the Intensity field. With the command line empty I can enter new channels and capture their tombstones and adjust, but the multi-intensity fixture intensity field is still Gold.
I'm using Luma panels (14 intensity channels per fixture) with individual dimmer channels in between.
1201 Luma
thru
1221 Luma
next patched channel range:
2001
thru
2084 as generic dimmers
then, next range is Luma again
2101 Luma
thru
2112 Luma
The command line functions properly, highlighting the tombstone and adjusting levels.
But when I'm on the screen page that has 2001 thru 2101 and I enter a channel in a different range, such as, 1101, my screen doesn't refresh to show me 1101. It stays wherever it is. When I page up or down, the next multi-intensity fixture channel tombstone is highlighted. each page button press just moves one multi-intensity fixture up or down. If I am on the 2001 page, and I enter [1101] [enter], then [Flexi] it refreshes the screen to show Active Channels: 1101 is there, then 1119 (correct), 1158 (correct, but, now it gets weird) it shows 5 thru 13 incorrectly each as '14 channel multi-intensity fixtures', without the name LumaPanel Bulb over the channel tombstone, instead it says Dimmer. BTW, these channels are out, no level. hash mark not a zero. They are not active. Then the next channel is 2001. which it should be. I am lost as to why channels 5 thru 13 are there in Active Channels. When I [Flexi], it changes up the numbers so the next time it read channels 1101, 1119, 1158, then 6 thru 14 as multi-intensity fixtures.
Now after a few hours of this activity the Page buttons don't do anything... Hmm
I usually have screen set to flexi-Show Channels. I have blocks of channels purposely un-patched.
I have a work around in ML Controls in the CIA; the channels show up correctly there, so I'm able to immediately see the level before I change it. After wrap I'll reboot & see what happens. If it doesn't clear up I'll go to the shell & Clear Persistent memory.
