I have updated to the current 1.9.5 Software for my Ion console and I noticed that I can no longer store things on a sub master by pressing Record than the bump button. Was this changed? Is there a way to change it back?
There are two things to make sure of:
1) Have you mapped the faders as submasters?
2) If you hit record sub, then hit the button, would that cause the fader to map as a sub?
This actually changed quite a few updates ago. It was actually returned in 1.9.5. However, instead of just hitting the bottom bump button you need to hit both the bottom and the top button symotaniously. You could also select any existing sub and hit the top and bottom buttons to place that sub on the faders.
Let me know if this helps.
