Effect bugs (I think)
Hello
Have noticed what seem to be a couple of bugs with effects in 1.9.6 of the eos software. Some of the bugs in the earlier software seem to have gone, which is good but the below still remain..
- removing an effect from a cue and updating Q only will correctly restore the effect in the next cue, however it doesn't respect any effect attributes you have recorded (using effect display), instead returning them to default
- Recalling the levels of a channel with an effect with recall the effect (as expected) but again it doesn't seem to recall the effect attributes, which is annoying
- The software will not allow you to have different attributes for the same effect on different channels (although this may be deliberate!)
Richard
