Is there a way to pull up unused channels on the Eos, including channels that "don't go about zero" without printing the PDF and opening it on a computer?
If there isn't currently a way it would be really useful (and make our designer very happy).
This would select any channels not used in the show, or more correctly, the current cue list. I'm not sure it's exactly what the LD is looking for...
Query {Isn't In} Cue 1 Thru Enter
There are many channels that are at zero (creating a blocked blackout cue) when a large range of channels are selected and set to zero and recorded in the cue. These channels never actually go above zero so aren't in the show, but are in a cue.
[Group][Cue] 1/first cue [Thru] 1/lastcue selects all chans in Q-list 1 that go above 0. Store this as a group and you can use along with [Group]-[Group] syntax to do useful tidy ups.
T
Thanks. I just learned something new.
That is very useful (and pretty much exactly what I was looking for!)
Do you know of a way to select all patched channels without knowing all of your patched channels (something akin to channel 1 thru enter in flexy view?). That would make creating a universal Macro very easy. Or ETC- is this a feasable feature add?
Matt
