hey everybody
for subs that are set as inhibitive, the button below the fader doesn't work as Group Select button. is that supposed to be like this?
cherrs from switzerland
felix
hey everybody
felix
Felix,
Unfortunately I am unable to reproduce the behavior you are describing.
Using Eos software versions 1.9.1 through 1.9.6, the behavior that I am seeing is that both types of Submasters must be at their respective home positions for the [Stop / Back / Assert] fader button to work as a Group Select. When the Submaster is off of the home position, the [Stop / Back / Assert] performs an Assert operation.
Submasters on an Eos desk, Virtual Submasters and Submaster mapped to a Fader Wing are all behaving as specified.
If you are seeing different behavior, please re-post to this thread with a list of steps it takes to reproduce it.
-Chris-
hi chris
not near a console at the moment. the show i was programming when i noticed this runs some macros moving two inhibitive faders up and down, so i can't tell you with absolute certainty, at which position they were. will re-post.
felix
hi chris.
sorry, false alarm. the inhibitive fader must have been at 0 when i tried to group sub. so, nothing to worry about...
felix
