Hello all,
For a lot of shows I do, I end up setting up as much of the console infrastructure as possible before load-in to save on time and budget. For focus palettes, rather than trying to guess locations, I generally just record and label every focus palette with the fixtures that need to be in that palette, then at load-in, I can quickly go through and Update my palettes so I have a complete list of accurate focus palettes. How I do this is by creating a cue list that just steps through each focus palette, and I can quickly update focus points as I go through the list.
Is there a quick and easy way to copy a group of palettes into a range of cues? Essentially, let's say I have 20 focus palettes all recorded. I want to put FP1 into cue 1, FP2 into cue 2, and so on. The closest I've been able to come so far was by using [Focus Palette] [1] [Thru] [20] [Copy To] [Cue] [1] [Enter]. This is exactly what I want, except this only copies the absolute data from the palettes instead of referencing the palettes like I need it to.
Is there already a way to do this, or if not, can this be implemented in a future release? Thanks much!
R
