An oddity discovered while recording submasters in 1.9.6
"Ch., XX, @, 50, Enter, Record, Press both upper and lower bump buttons" records the sub.
If desiring to re-record the sub, same command line syntax except you only press the lower bump button plus Enter to confirm, to re-record the look. (As opposed to Record, Sub, XX, Enter, or doing an Update, Sub, XX, Enter).
I understand the reason, as once the sub is recorded, pressing the upper bump button selects the Group list for that sub.
Just seems counterintuitive to press both for one record and lower only for a second. Maybe go back to initial record only requires the lower button be pressed ?.
Steve Bailey
Brooklyn College
