If I have selected several different channels. and made some adjustments to each of those, is there a way to quickly re-select all of the active channels without manually going back and re-selecting those current channels?
if you hold the SELECT LAST Key down,
a softkey choice SELECT MANUAL key in the LCD display will appear.
Press that softkey, and then it will select the manual changed channels.
Use the Select Last button to select the channels that were last manipulated. If you press and hold Select Last, there are additional soft keys for Select Active, Select Manual, and Select All.
Edit: Drat, 2 other beat me to it in the time I was typing.
I really didn't want to start a new post just for this very small quick question, so excuse me for highjacking this perfectly titled topic.
Is there a hard key/shortcut for AllNPs?
I only know where to find it in the filters area on my touch screens and every time I wish there was a shortcut like a [Shift] & [Insert appropriate Key]
I'm hoping there is a quick answer. Thankyou
Its a couple key strokes and a two handed operation, but if you are on an Ion without a touch screen, I find it faster to Shift and Tap the encoder selection Keys (Focus, Color, Form, Image, Shutter) than to get to the mouse and mouse to ALL NPs
