I am newer on ION.
I know how to channel check, but how to check intesity by dimmeer.
For example, We haven't patch dimmer 5 yet, but want to call it on.
I am newer on ION.
Welcome!
There is a softkey when in live most likely S2 if I remember correctly that is {Address}. You will select {Address} [1] [At] [Full] or level desired enter. To go to the next or last dimmer called up, select [Next] or [Last]
Hope this helps!
Jared
