Daft as it seems I can't figure how to set the screen clock to the right time! The date is correct, but not the time.
Searching for 'clock' and 'time' throws up an awful lot of unrelated info...
Quick answer?
Quick answer?
Hi Tony,
You need to Exit Ion and go to Settings>General. It's at the top of the list there.
It will probably ask you to re-boot afterwards.
Graham
There you go - I KNEW it had to be simple...!
Thanks Graham.
Tony
Exit ion and it is in the settings under general. Once you have made the changes apply and go back to the Primary. The change should take effect immediately.
Thank you for that most precise tip.
