Hey all,
Just wondering if when running multiple cuestacks, there's a quick way to tell [in LIVE] which channels are being controlled by which cuestacks?? Such as colors or holding down a key or something??
Thanks All!
-T-Rex
Hey all,
Thanks All!
-T-Rex
If you select the channel, then press the [about] button it should tell you the current source of the selected channel. This is located under the current values tab. Hope that helps.
