Presets
Presets Abruf bei der EOS!
Wenn ich ein Presets abrufe bzw. per Doppelklick die beinhaltende Kreise anwähle ist es mir nicht möglich diese dann per At (wert) hell sondern nur per rad auf einen Intensitätswert zu setzen! Ist das eine einstellungssache oder ist dieses in dieser Software Version nicht möglich?
Presets release of the EOS!
I check presets or select one with a double containing the channel, it is not possible for me by AT(value)only with the wheel it then set a light intensity value! Is this a matter of adjustment or is this not in this software version?
  • Hello, I'm not sure I fully understand the question so perhaps one of the German speakers in the community will post a more accurate response but here goes.
    If you have a Preset that switches the light on when you double click the preset you can remove the intensity value from the preset.
    [Preset] [Preset] - Opens Preset Window
    [Preset] <preset number> [Enter] - Selects preset you want to edit.
    {edit} - Opens edit window and shows you channel values
    <channel number> {intensity} [At] [Enter] - Removes Intensity from Preset
    Now when you select a preset by double clicking it the light will go to the preset without intensity. You can then set intensity with the wheel or the [At] Key.
    Or if that's not what you meant and you just want another way of setting a channel to a Preset you can use the syntax
    <channel number> [Preset] [4] [Enter] - sets the channel to preset 4
    Hope that helped...
    All the Best
    Sabr
    [edited by: Sabr Hemming at 6:20 AM (GMT -6) on Fri, May 27 2011]
  • i'll re-translate:
    "when recalling a preset or selecting the channels contained in the preset by double clicking, it doesn't seem possible to change their intensity with [at] (value) [enter], but only by using the wheel. is this a matter of settings or not possible with the current software version?"
  • Thank you Ueli
    Well I was right off the mark! never mind was worth a try! In any case it is possible to change the intensity Value of a moving light with the [At] key or the level wheel.
    Teaser, are you able to set intensities of generics and other units with the [At] key?
    I would go into the shell and perform a Deep Clear, make sure you save your show first. Beyond that I wouldn't know I'm afraid.
    All the Best
    Sabr.
