On my playback screen I want my "Master" tablet to scroll down so i can see all my sub pages. How do I do that without adjusting the size and resolution. At the moment I can only see sub pages 1-10.
You will only see pages 11-20 if you make one of those pages active - same for 21-30.
Hope that helps-
-luke-
These pages are already active
If you put focus on tab 2/PSD - press the format key. This will give you a split cue list, the master fader and detail on the current page for the other 10 faders. Press format again. This will give you 1 cue list, detail on the master fader, and a display that shows 10 faders x 10 pages. There are 30 pages... so this is oriented around the page you are currently on. There is currently no way to see the levels of all 300 faders at once.
Hope that helps.
a
When i do this the master list is oriented around page one, which i am currently in, only displays that page row while changing the cue list size and position
I'm confused. The area called "Master" always shows you what is loaded to the master fader. Changing the cue list size (zooming it) does not impact that data. The part across the bottom of the screen, which shows you the detail of the 10 faders for the page that you are currently on doesn't change unless you change the fader page. And then it will follow the detail of the current page.
Which of the three PSD formats are you currently trying to work in?
a
I am currently wokring in sub page 9, on my display subpage 1 is highlighted (not 9). the master display is showing my the pages 1-10. What i did before to see the other sub pages, not work in, was : selected my Pbs page with the mouse, hit and hold "Fader Control" and hit the "Format" key
Ah, you are on an Ion with wings, aren't you? The PSD does not reflect the pages of the wings....
The format key and the Fader Controls keys are completely unrelated functions. Format is a display function and "fader controls" are playback functions. So, I'm not sure what you did before, but I wouldn't expect anything to happen.
You are probably going to be happier using the third PSD format. Can you try that?
Hope that helps.
a
I am on an Ion with wings, I am currently using the 3rd PSD format But I am still confused on what keys I have to press to look at my pages 11-20. Sorry i do not know a lot about this board, I get by with the basics for most boards. So you may have to break it down for me. Thanks for your help
Hey,
I've just posted this on another thread and figured it'd be good to share it over here as well.
While you have focus on your PSD tab, try pessing ] on your external keyboard.
Note: You'll have to cycle through the faders using ] before the page changes.
Here's the result.
Is this what you'd like to have happen?
BTW these images are from v1.9 and does not work with v2.5 and possibly v2.4
Regards,
Johnny
