Running two master lists on Partitioned ION
Hey Guys,
I have two partitioned IONs right now. We have conventional lights on one and moving lights on another. We are creating two cue lists , one for movers, one conventionals. My question is: What we are finding is that we cannot run two master lists at the same time.
We want each programmer to be seperatly programming, updating, and moving through cues. ie the ML op can program while the conventionals move on.
Is there a way to ahve two master lists at the same time????
Sorry for my bad typing,
~Meghan
  • Hi Meghan,
    I assume you want to have each Ion have their respective master list control a different list. On one of the Ions, go into Setup, then Show Settings. On the far side you should see an option for Fader Configuration. Once in Fader Config, notice that the Master Fdr is mapped by default to 0. Change this number to 1 and press close, then Ok. This will allow you to map a different list to each of the Ions master fader.
    Once you make this change in Setup, you would then need to load the new cue list into the master fader.
    Note about The Mapped To #: If the same number is used on multiple faders, those faders will share whatever you have mapped.
