1. when pressing channel <x> full, no need to press enter
2. board is web-enabled and will auto-update its software
3. back lit keys
having fun, preparing for our first show using the board.
3. back lit keys
Hi there,
both features are already in :-)
[Group] [Color Palette] 16 [enter]
selects & sets all channels involved in CP16 to CP16 (same for Int/Focus/Beam/Presets/Cues/Subs and step-based effects) ;-)
If you want to select the channels only (without putting them into the Pal), you could use
[Query] {can be} [Color Palette] 16.
And to make "all currently in red to blue":
[Query] [Color Palette] blue [Color Palette] red
You might need to use a keyboard shortcut to access [Query] on Ion.
Cheers,
Markus
Press Level button for full int. and you will not have to press enter. They will never let it be web enabled, it would be to easy to get a virus. I do love the idea of back lit keys, how sweet would that be. Good luck with your first show, i'm programing my 3rd show now and it does get simpler, or my brain thinks so.
Can I
please have a [clear-command-line-before-running-the-macro] command to put in
front of my macros? Tonight I fucked up
(probably) again, when parking my heads power with a macro while I was working
with something else… - and didn’t realize…
( - you
never know how many [clr]’s you need, and [undo] are dangerous if it’s nothing
there…, strand 500 had a [shift]+[clr] command which cleared it all…)
- or is it
another way?
That's a good idea about adding a macro command to clear your command line, we'll put it on the list. If you are tempted to use [undo] in your macro to clear the command line, try [undo], then [clear], that way, if you use the macro from an empty command line, the [clear] would clear out the undo command, and you would always end up with an empty command line.
For others breading this, [undo] when pressed from anything other than an empty command line, will clear out the entire command line. If your press undo from an empty command line, undo is placed on the command line and the undo command list appears.
Would it be possible to make discrete timing one of the columns in the table view of live. Currently the only two ways that I know of the see discrete timing is to go to about cue, or to press and hold the time key.
I just finished designing my first show with Ion and was very happy. Here's my list:
- To assign a curve, [Cue] {Curve} n doesn't just assign curve n to the current cue -- I had to give it the cue number as well: [Cue] x {Curve} n
- In chan check, putting the screen in a flexi display should allow the user to [Next] over channels which aren't on the screen. Instead, the hidden channel number just pops into the active tombstone.
- Unpatching dimmers didn't seem possible in the patch by channel display. [0] [@] x produced an error.
- I would love if the help key worked for all soft keys and touch screen buttons.
- I missed having a button for Select Active and Select Manual. Perhaps holding down the Select button could populate the softkeys.
- Could there be an option to show the softkey labels in the corner of the screen, like in the offline editor. I often find myself working with a programmer who doesn't know the board as well as I do, and I like being able to see what keystrokes are available.
- Could gel colors labels in the color picker display in data as though they were color palettes. The labels should have some sort of indication (brackets, bullet point, italics, etc.) to distinguish itself from an actual color palette which might have the same name. When building a show with limited cueing time, these instant palettes would be a real time saver.
Keep up the good work.
-Josh
Hey Josh....
some thoughts.
Will look into the curve issue - your syntax should auto-populate the selected cue number.
In 1.4, Next/Last will work through only the channels in your current flexi-channel state.
Unpatching dimmers in the channel display. [x] [at] [0] [enter] -- where x is your channel number should work. [Address] [0] [at] [x] [Enter] - where x is your channel number doesn't because address 0 is a phantom entity. It's the same as [1] [at] [Enter] for a channel, where this action is just saying..."remove the current data."
Yes, Help is an ongoing project.
We have some ideas about getting [Select Active] and [Select Manual] into Ion. A shift/softkey function as you describe is among the possible solutions.
I understand your point about the softkey labels. We've avoided that sort of thing to date to avoid clutter on the screens. We've got several more advisories that we are considering adding the the live/blind channel display and am concerned about information overload.
In 1.4, we are changing the way certain data is displayed. Setting a frame table device (such as a scroller, color or gobo wheel) will result in a Frame number and label, rather than absolute DMX data. Similar to the encoder display, we will use a + / - to tell you when you are not in full frame. And setting color from the gel picker will display the gel number (R80).
Thank you for the feedback!
Anne
Hi Anne,
Thanks for your replies.
Regarding unpatching dimmers -- what you say makes sense. I was trying to unpatch one of two dimmers "twofered" in patch. I figured out that what I was looking for is [x] [Part] [y] [Delete] [enter]. Channel 0 was a useful patch concept, but the graphical address browser is a more than worthy replacement.
Speaking of which, I just noticed that clicking around the address table takes me to that channel not the address. Is this a bug? I would think that the address table could be a handy way to jump to an address while still viewing the hookup by channel.
Also, I love the [Move_To] feature in patch. Could there also be a Swap_With option that swaps addresses between channels? Maybe a 3rd press of the [Copy_To] button?
If you do implement softkey labels on the screen, I definitely think it should be an option in the settings.
Great news about labels in 4.1 -- I think that makes a lot of sense. It would be great if there was a way to easily distinguish the label for the gel picker R80, and my R80 palette. Even better would be a way to update the values from the color picker (for example, the scrollers are in the R80 frame, the wash fixtures mix to an R80, and the spot fixtures are in their primary blue on the color wheel), but that may open a big can of worms.
Cheers,
Josh
A few things I'd like to see in ION (alternatively, correct me if they already exist!):
Mainly I'm just missing a few EOS buttons.
Select Active - sounds like this is in progress, which is great as I use it all the time.
+/-% keys - I was quite surprised ION doesn't have these as most people I know use these a lot. I guess a macro "@ +05 ENTER" would do it, but is there a softkey option in the future??
Filter key - am I missing it, or can we not yet use filters on ION??
Otherwise no real issues!
Thanks.
a tiny, little, outlined wish
Most of my eos-screens are dedicated to programming. That’s nice. And
it is the cue we are programming that is marked. Not the next. Here in Norway
we rarely use a cuemaster (I am my own, and sometimes rather confused and
busy).
So could you please make me a dedicated, tiny, little, outlined window
fx. down, right in the playback screen that tells me to all times just what
will be triggered when I press GO next time? Just [cuenumber] [time in/time out] [label]
Something like fx.: cue 217 3.3/7.2 Anne slaps
Tryggve in face twice
For all other info; I’ll search elsewhere on my screens.
t.
