Inhibits
Hello,
Can I ask if there's any plans to improve the way displays deal with Inhibits? If you completely inhibit eg Haze at the moment, the channel disappears from the display. (For me this is an issue because I always use Flexi Active when running cues). I'd love it if the inhibited channel could stay on the screen, with a zero, so that we know it SHOULD be there but isn't? This way, I for one would realise much sooner that I should probably take the inhibit off at some point!
The other thing is when you're running eg haze in a palette (eg Haze 10%) and you inhibit it, I think I'd like it if the name of the palette disappeared when you started inhibiting, so that you could then see what level the haze really was at. Instead of squinting at the sub to see what level the inhibit fader is at. Is it possible to do that or am I asking for the moon on a stick?
Jane
