When I'm using the FAN function, is there a way to then disable the function without having to re-select the fixtures? I would expect to see a soft key labeled "OFF" or "DISABLE" for such a function, but none exists.
For example, I'm using FAN to spread the pan values on a line of fixtures: 1 THRU 5 FAN ENTER, <PAN ENCODER>. Then, to tilt them all together, I have to use [SELECT LAST], correct? Or is there a more elegant way to do this?
