NCE works in Fusion
I'm not sure if this is the right forum for this, but since I'm using an EOS I figured it was appropriate.
I've got a macbook, and I run VMWare Fusion.  To run NCE, just plug into your network, disable airport, and start Fusion.  Go to Setting, Network, and select "Connect directly to the physical network (Bridged)."  Change your IP address like usual in Windows and your all set to go.
Mike Ohsann
