I was wondering what is the quickest and easiest way to check your focus/beam/colour palettes in the most elegant of ways.
My first thought was this. If you had a Preset for every focus/colour/beam palette then go into Channel Check mode. You could press the presets bringing up, if you desires, the correct intensity of that light for the scene and put the light in the position of that scene. - Obviously this doesn't work due to any other key press other than [Next] or [Last] terminating channel check mode.
So my second thought was using highlight mode.
After making all your presets, make a group with all of your moving lights and type
[Group] [1] [Highlight] [Enter]
Then select your presets to move the various lights to the positions. While this works it doesn't turn off the lights that aren't in the preset you've pressed and so maybe you might find yourself with lots of lights all over the place. I was hoping for something a bit more elegant.
What I was after is a way, and maybe there isn't one without writing a macro, to press the presets on the direct selects bringing up the lights only for that preset and rem dimming the rest. It would mean you don't necessarily need to know the channel number straight away to check the position. Any thoughts tips/ hints?
[edited by: Sammy at 4:46 PM (GMT -6) on Fri, Aug 5 2011] finally figured out why my posts were posting in a bad layout.
