I was just trying to check the differences in Scroller calibrations between units, and found this anomaly...
When viewing About > Current Values - there is no way of seeing DMX Levels for a scroller.
However....
under Background, the DMX Column shows the Current Values, where as the Background column shows the Background state. IE when you change frames on a scroller, the DMX levels here change, but the Background level stays static.
Is this intended behaviour? Seems counter-intuitive to me. If anything I think that we need to add a DMX column to Current Values and fix Background DMX column to stay static. Or am I missing something?
On a side note, is there a way to copy Scroller Calibrations between fixtures? And is there a way to see that a calibration has been made to unit and that it is not at default settings?
Perhaps some kind of Flag under About could show that a scroller has been calibration modified?
Warren
