It would be nice (in ION world, at least) if there was some way to gracefully shut down the ION when it has been powered up without it's monitors plugged in and powered up....especillay the DVI's which don't wake up after the fact.
Currently, all you can do is hold the power button down until it dies.
It would be nice to be able to hold down some key-combination and maybe get an advisory in the LCD that could walk you through a graceful shutdown. This also needs to work when the application is not running.
How about you hit [live][blind][display] together 3 times in a row, and then it briefly tells you in the LCD to type in some shutdown code, such as [4][1][1][6] to shutdown or it clears in 10 secs.
Just a thought....
