Two parts in this question.
I am new to ION. I am used to using a console that has the ability to record looks stacked on top of each other on each fader. When that fader is raised all I have to do is tap the bump button and the next look plays. I can tap as fast or slow as I want and it will continue to advance stack by stack, over and over and over. That fader can be set to reset to stack 1 each time it is brought to 0 or to remain at the last look played back. I can also tap another fader bump button while one fader is already up and it will flash to that second look then when I release the bump it will snap back to the one already playing. Because of that I can keep fader 24 (example) up all the time as a "between songs" look so that when all other faders end up turned off 24 will automatically be playing.
The console has a total of 24 faders with ...# pages. I seldom to never used that feature in the theatre setting. In the theatre I recorded cues and ran it like the ION, using the GO. I ALWAYS used the bumps for concerts. Having literally hundreds of pre-recorded looks I could run the show strictly from that and never need to make changes on the fly. All I needed to know in advance is if the band songs were slow, med or fast and I could plan on what to play back based on that.
Soooo now with the ION I know it does not have that ability technically, however I understand I can just record cue lists on each fader and that should take care of that in a similar fashion.
My first question is am I on the right track? Can I just make a boatload of different cue lists and store them each on different faders then play them back by raising that particular fader and tapping them to change them. I assume I also need to make proper settings on the bump butttons.
Second question is because I will always be all over the place playing back looks in concerts, should I run the console for concerts in the Cue only mode rather than Tracking and keep Tracking for Theatre.
Third question would be how to put cue lists on faders.
Opinions are great and I'm all ears.
