Have multiple cue lists on IMasters 1 - 10. Each one a different cue list. All contain movers, NO Led's They are also all set to HTP and all set to Assert. Cues 1/1-4 are on Fader 1, Cues 2/1-4 are on fader 2. Cues 3/1-4 are on fader 3 and so on.
I bring up fader 1 and keep it up. I can bump any of the GO bumps to change any of the cues to show as the next cue. So Cue 1/1 Red and Blue is running. I can tap the GO button under fader 2 to switch to Cue 2/1 Green and White and it will play. I can tap the Go under fader 3 to switch to Cue 3/1 Orange and Yellow and it will then play. I can then tap the GO under fader 2 and it will switch to Cue 2/2 same colors as 2/1 but an effect runs. I can then tap the GO under fader 1 and it will switch to Cue 1/2 same colors but an effect runs. I can then tap fader 2 and Cue 2/3 some color changes will play. An so on back and forth as much as I want flashing cue to cue to cue all over the place. All cue lists link the last cue to the first so I can keep on doing this as much as I want.
Soooo now I have attempted to do the same thing with my TriColor LED drapes. I only created one cue on each list and I am using Effect 914 for color chases. I've made all my speed, size, Horiz, Vert etc settings appropriate for the colors I desire and recorded them as Cue 41/1 Pinks and Blues and Cue 42/1 Greens and Whites to start off with. Well I bring up fader 41 and tap GO and that cue plays perfectly in Pinks and Blues. I then tap GO under fader 42 and that cue plays perfectly in Greens and Whites. When I go backwards to tap fader 41 again to change back to Pinks and Blues it stays at Greens and Whites. ?????????
Also can anyone tell me how to remove Assert from a cue list running on a fader? I enter the desired cue say 41/1 Enter. Then Cue Cue to bring up the Cue list highlited on that cue. I can use Fader to switch IMaster, Independant, Etc. Solo Mode, Independant, Fader, HTP/LTP all work but when I hit Assert Enter it does not go away like other toggles do.
