If I understand correctly none of the Eos family console offline editors will output UDP strings in offline mode. Is this correct?
[edited by: paco3346 at 9:41 AM (GMT -6) on Wed, Oct 26 2011]
Ah, no, not the case. This was verified on a PC using the offline software and it worked fine.
a
That's not the answer I was given when I called tech support last week. From what I understand the offline software only outputs to visualizers.
