Couple of questions regarding submasters ...
First one - say I've got some channels with non-intensity parameters recorded onto a submaster. What I'd like to do is to have the NPs snap to their recorded value when the fader leaves zero, and the intensity fade in according to the fader being raised. That bit's simple - I can set the fader to be an intensity master and that does what I need. Then, I need to happen, as I return the fader to zero, is for it to release all the NPs that it grabbed hold of and return control of them back to the main cue list. I know I can do this by hitting the bump button to 'turn off' the sub, but is there a way to have it release the NPs automatically once the fader gets back down to zero?
Second question is along similar lines, but related to effects on subs. If I've got some channels programmed in a sub to be running an effect, is there a way to get the effect to start and stop when the fader leaves and returns to zero, without having to hit the bump button to start and stop it each time?
Both of these things are easy to accomplish on my little MagicQ PC-based console by setting a 'fader releases stack' option - so I guess I'm looking for something similar on Eos. Does it exist?
