Flashing Movers
I am on my Ion with one fader wing attached. I have some movers that I'd like to use for lightning. There are a couple different scenes like this so I have them focused in different locations for each scene. What I'd like to do is assign each unit to a button on the wing so, that no matter where they are pointed, I can flash/bump them on cue. I am sure this is probably pretty easy, but I am just missing something! TIA,
  • If the NPs are written into the show's cues, I would make sure that only the intensity is assigned to the fader.  Also try playing with the dwell time, I might start about .3 to .5 seconds.
  • If you record each of your lights intensity into a sub and then assign your subs to your fader then that should accomplish what your after.
    You can:
    [channel] [x] @ [Full] [Enter] [Channel] [x] [intensity] [Record] [Sub] [1] [Enter]
    [Sub] [1] [Enter] - then press the too buttons underneath the fader you want to assign the sub to.
    If you press the bottom button it should flash intensity of that light
    To play with the fade up/down, delay, latching of the sub, Double hit [Sub] you will see them in the column and you can use the softkeys S1-S6 to select which option of the sub you want to change.
    Hope that helps.
    [edited by: Sammy at 5:35 AM (GMT -6) on Fri, Nov 4 2011]
