lamp controls in irfr?
I noticed the other day that in the patch section of iRFR, theres a lamp controls soft key.  I cannot figure out what this does, however, or how to use it.  If it's possible to do a recal or lamp on from the iRFR, that'd be really cool, but how do I get to it?
  • Hey H,
    This stumped me also for quite some time. The product support folks were eventually able to help me out with this.
    While in patch mode, select the fixture you would like to control and press enter. While holding down the lamp controls softkey, use the scroll wheel to select the desired action. Still holding down the softkey, tap on the scroll wheel and that should put the selected lamp control on the command line. At this point, you should be able to press enter to send the command.The whole process is a bit awkward, but it has worked for me before.
    Hope this helps
    -A
